Regards. Maurice
Dead Beocenter 9300
Regards. Maurice
Did you check all the fuses at the back of the transformer?
Hi beobuddy
Thanks for your reply yes I did check those fuses they were all ok
Regards Maurice
It's unlikely to be a failure of the main transformer.I don't think I've had one fail yet.
It's common for the 5 volt supply to fail though,due to dry joints around the main power supply cap's.They are on sub board mounted near the transformer that carries the relay's too.
Nick
You can measure ac output straihgt from transformer also.
Nick
Despite the known fact of bad solder joints and the present of the 5V, there is a chance that one of the AC fuses is blown which causes a dead 9300.
Hey Maurice, I have the same problem and are trying to get standby PCBs to my Beocenter 9300th
My question:
1 - What do you mean by QDA? it is a business.
2 - How can I order the same standby PCBs
3 - Do you have any numbers on the PCBs
Best regards
Jan
www.beoshop.se
Why would you replace the board? These are repairable.
If you can't find a replacement, you can send it over for repair. No problem.
Thanks Beobuddy, maybe I'll do it.
You might if you have experience in the PCB63 can give me a tip how I can fix it?
Best regards
Hi BeoBeo
My 9300 looks to have suffered the same problem. No life and the PCB tracks from the F1 output from the standby transformer have burnt through. The resistance of the coil is measuring 0.2 ohm across the F1 leads so probably no good.
Did you find a way of getting a replacement transformer?
Thank you
