hi guys does anyone know if you can copy an eprom of the stb-c type old beovision avant crt?
what kind of new empty eprom do you need?
Has anyone done this yet?
If I remember correct, a MC27C4001.
Avant 32
Donβt know why I wrote that as the 4001 is used for software for BS9000, 3000, etc.
I meant to write 1001. All these eproms are OTP, one time programmable. So make sure which settopbox you need to control.
Willem EPROM Programmer
http://www.mpu51.com/eprom/eprom.html
https://www.gotronik.pl/programatory/willem7.html
That looks ancient...
Before you spend the time and effort in trying to find the chip with the right specs (which might not be as easy as you may think), it's better to confirm whether your programmer supports the chip and you have the drivers and the PLCC32 adapter available! Just read out the chip multiple times and see whether the result is consistent and the data makes sense.
(I've had some bad experience with programmers that - in theory - were capable of handling certain EPROM's but in the end they just didn't do their job. π Therefore I'm now leaning more towards a "try first, buy later" philosophy. )
You say you want to copy the EPROM STB-C from the old AVANT, but there were a large number of different programmed chips and upgrades.
Look at the WiKi HERE for the last ones I updated the list. Each chip has a "Software Version" and a "Table"
What Set Top boxes do you want to support on your old AVANT?
Because a large number of old AVANT's are scraped it would be easier to get an existing chip from an old unit being scraped.
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
