Hi
So unit turns on
Windows not sliding open
Pressing CD goes to CD or radio or tape
But when pressing play give the sign as there is no CD and not spinning of course. Same with BEO4
Same for radio or tape.
Any help on the PCB to check first, I have all PCB for a swap.
Once ok will dig more deeply once PCB located.
But it's a pain for some PCB so I rather go right away to the correct one.
Tried resetting but no effect. And sometimes when knocking on the back it works until you turn it off and next day same thing again.
Thank you
