CDX woes
Thanks sonavor!
Thanks you all guys! All the best!
Hello everybody.
I have troubles with my CD X. I have read all topics here on the forum about CD X and its issues. I get my CD X many year ago as present in non-functional state. For many years I have been thinking the CDM fails. Last week I bought another CDM from eBay, change it and no change happen. Now I know it was pretty stupid move but it kicked me into fixing it.
  1. The original issue was ? on display after pressing play. Motor was spinning few seconds and ? appeared.
  2. I changed CDM
  3. Same issue ad point 1
  4. I fixed all rivets/griplets (resolder it with copper wire pushed thru) on decoder and servo board
  5. After the rivet fix, there were strange issue with motor not stop spinning even lid open. I let it be for one day and the strange issue not appear anymore.
  6. The original issue is back/still here
  7. I checked pin14 connection with griplet as described in this topic
I am not good in electronic but I do not want to resing.
Do you have any idea, what i can/should do next?
Thank you very much!
Hello
i m searching for the white gear as mine is broken, but I don’t see it anywhere on the web, if someone has an idea…
Great ! Keep me updated when you have the part!
best regards
New gear pulley for the Beogram CDX, CDX2 and CD3300 is now in the webshop.
To me it came in perfect timing, because I have a CDX on the bench where the owner had fitted a 3D-printed gear bought off Ebay.
Not only had a tooth broken off already, its rough and coarse surfaces managed to eat a new belt in just a little over two months, leaving nothing but rubber dust everywhere.
Beoparts-shop has the real thing. Belt too.
Hello dillen will you make the other gear ? The big white one that s just after the one you are making? I need this one as mine is broken.
regard
regard
regard
That's the first time I hear about this gear breaking, and there are no plans for reproducing it,
but I'm sure I can find a good one in the dungeons.
PM or email me.
