CDX no sound -griplets?
I agree with Martin.
Reed relays are dirt cheap and a doddle to replace. The other relays are for CDs that have treble boost (pre-emphasis).
In Spotify, for instance, they can't be bothered about that and those CDs are incorrectly ripped, which makes them very bright.
Hello ,
Sorry for being a pain and refresh the post( I have same issue with my CDX)  Where can I locate mute relay?
Thank you.
Hello ,
Thank you.
Rearmost on the decoder board.
Thanks for quick answer, I have re soldered joints of those elements and CDx is back to life :)
Thanks for quick response, I have re-soldered the joints of those elements and CDX is back to life 😁
