I have just bought a CDX and a beomaster 3300.
The sound is great but I wanted to know if it was possible to replace the RCA output from the CDX with a seven pin din connection so that I can control the CDX with the remote for the beomaster. Would this be possible?
To that extent, does anybody know if it is possible to buy a seven pin din switch so I can expand the number of B&O inputs I can connect to the beomaster. I quite want to connect another B&O cd player (crazy, I know) but the beomaster 3300 only has 1 cd, 1 tape and 1 phono input.
Thanks for the help!!
