Hi all,
I have a Beocenter 2600 (thanks Cleve!) and I've been looking for a CDX but it's proving hard work. Could I just plug in any old CD separate if I got a twin phono to 5 pin DCI in the meantime?
Hi all,
It'll be fine. Just make sure you get an adapter that is wired for the correct direction: from the phono/RCAs to the DIN, and not the other way round, as both are possible.
A 4xRCA adapter would be a safe bet, as then you can just try out which two are correct.
That was quick and easy! I was worried there might be a problem with line volume (or some other thing I don't understand!)
Thanks Tournedos.
I lied. Still not quick and easy for an idiot like me!
Is this what I need? I'm struggling to find a cheaper version. Everything else seems to want to go to the rca connectors.
It can be confusing!
A far from cheapest solution is
