I just installed new capacitors in one of my BV2600's because it sounded terrible (planning to do the other as well once this one works fine). I used 8.2uF 70V and a 22uF 50V since it was the only thing available in my local shop but this should work fine. I did not replace the resistor and coil.
When testing the speaker out now, the higher tones sound perfectly but the lower tones are just not hearable and a bass is just a strange sort of noise. I believe the cone (I don't know if this is the correct word for the complete black thing which produces the bass tones?) itself has a problem somewhere but it LOOKS fine and I don't really want/dare to open it up.
Any ideas what could be the problem or simple things to try out to find the problem?
Thanks for your replies in advance!
Laurent
