High!
If i build/prototype a cable with 3.5mm mini klink, USB for providing 5V trigger and use this on a Beolab (2 and 7-1 in this case) with source Laptop or Phone, everthing is just fine.
If i do the same with RCA plugs and not 3.5 mini klinke, and use as source a AV-preprocessor there is heavy noise. If i then use this exact cable with RCA to mini klinke adaptor to test again with laptop/phone the signal is clean again. This happens with 2 preprocessors that i own. The second preprocessor has only noise on righ channel, though.
What the?!
Has anyone experienced the same?
