Hi very interesting your answers.
a) By the way, the new 'Beolink Converter NL-ML' can help, for example or you always need a Sound System in the room with this dos Beolink Converter. Do you know how is the best connection, and how it works?.
b) IMPORTANT: I understand that it is impossible listen the sound equipment (Bs3200 or Bs5) as secondary equipment in a periferical room without directly speaker connection, where you have a Beosystem or Beovision with connected speakers. (Martin said).
c) Stefan said: I understand you can hear all sources from BS 3200, and BS 5, if BS 3200 (A.Opt 0) Beo Vision 5 (V.Opt 0)? ok Living. and BS5 No Audio Master (Off) . And the by Biocontrol 4 touch N.Music/N.Radio? GO (file music library), N.Music GO 1 (number 1 BControl4) Spotify, and N.Music GO 2 (number 2 BControl4)A.Aux?. I thougth only in Yes Audio Master (ON) BS5BM5 works with CD,Spotify, and Aux.
