Martin: 🙂 EXCELLENT THANKS, its the first time I have an answer "excellent one".
I told you perhaps you can help me more. and its interested to know from B&O users.
We have via Master Link all the apparment
Living: BV5 (5.1) Option 2 frontal BL 8000 sw BL2 back BL 6000 & BS 3200 Option 0 (via aux a BS Essence 1st Generation)
Kitche: BL2000 Option 6
Study: BeoLink PC2/BeoPort Box ( 2.1) BL 4000 sw BL11 PC (XP) (old) with BeoPlayer Option 6 BeoConnect Soft and BS2. We will set a Mac Mini (El Capitan) instead of PC (XP) sure and perhaps secondary a Notebook Dell Inspiron (Win 7)
Play Room: BSy3 (5.1) Option 6 BL 3 sw BL11 back BL 4 & BS5BM5 Option [Audio Master: No=off]
Suite: Active Link Box Option 6 Eye Link (2.1) BL 4 sw BL 2.
All Rooms we can hear . a) Radio,CD,A Men or CD Men from BS 3200. b) N.Radio N.Music from BS5BM5 [Audio Master: NO] so we can not listen Spotify, CD BS5, and no AUX (to connect example Airport Express) we think.
Study we can hear only a) Radio,CD,A Men or CD Men from BS 3200 c) N.Radio N.Music from BeoLink PC2/BeoPort Box Beoplayer Soft (we think its old nowdays) besides PC (XP)
Living we can hear besides the same of All Rooms, the BSE 1st Generation) BeoMusic App, Spotify, Airplay, DLNA, TuneIn Radio, Aux.
DOUBTS
If it is possible How we can get the best B&O set up.?
Because we think Study: PC (XP) BS2 and Beolink PC2/BeoPort Box (no works with news product like Mac Mini (El Capitan).
What we can do?
1st) We like go on listening All rooms possible Radio,CD, AMEN/CDMen from BS3200 and NRadio NMusic from BS5.
2nd) We like activate from BS5: Spotify, CD (if it is possible), and Aux to Connect AirPort Express, with Airplay. [Audio Master On=yes]
3rd) Study (Perhaps nowdays its old BeoPlayer Soft we lost BeoConnect Soft unless we use Dell Inspiron (Win 7) to connect with BS5BM5, we think its old BeoSound 2 (we could have iPod).
PERHAPS Ideas we think (but if you have something better we are interested)
Cost/Set Up
A) You know if it is the possibility to connect both BS 3200 and listening All Room Radio,CD, CDMEM/AMEM or Connect BS5BM5 [Audio Master: Yes=on].
B) Playroom: If we connect a "Y" Powerlink from front speaker and sw besides BSy3, example connect BL3 and BL11 now also directly to BS5BM5 we can do 1st) 2nd) . Set BS5BM5 Audio Master Option 5 and BSy3 Option 5. Besides to avoid change place equipment (we dont know but we think if it is the same problem you explain with BS 3200 (only in this room hear the equipment) or is different with BS5BM5.
Another way to avoid change place equipment, is set Study an Active Beolink (Option 6) so we can do only 1st) and with a Power link "Y" directly from BL 4000, you can add BSE (1st or 2nd) generation. The BeoLink PC2/BeoPort Box must take off (draw). What do you thik this?
C) Perhaps sending BS5BM5 Option 0 to the Living (adding Airpot Express) Airplay and the BeoSound 3200 where? to the Study or to the Playroom without losing hearing Cd,Radio,A.Men/CDMen AllRooms. Now you get your first answer we think it is not possible. Are you agreed?
D) Perhaps one interested possibility but changes equipment places is BS5BM5 Option 0 Living (Copy all CD memory 3200 again) "via Aux set Airport Express (Is it all right this)". And Set the BeoSound 3200 to the Study with the BSE (1st Generation) via AUX.And If we want we use Beolink PC2/BeoPort with the Dell Inspiron.
E) Or It is convenient only set directly in the Study a BSE (2nd Generation). What do you Think
F) Study if we set directly BS5BM5 with BL 4000 Option 6 (its the same you explain with BS 3200) only we can hear NMusic NRadio in this room?
THANK YOU
