BS 5 doesn't change AM Option
Hello,
I have the following problem, my Beosound 5 was previously connected to a BV 9 with option 0
and can now be operated as a standalone on option 1. If I switch to option 1 it does not accept this,
the sound settings do not appear and it does not respond to the remote control either.
I have already made a recovery and now don't know what to do next. Does anyone have any tips?
You need to change the behaviour under settings. BM5 will not respond to option settings via remote.
Also, do you have speakers connected ?
/Weebyx
thanks for your answer, yes i did it under Settings and speakers where connected...
