Bringing a pair of Beovox 5702 back to life...
Hello all,
After a long while keeping my eyes open for some I've just acquired a pair of Beovox 5702. I've been using my Beovox 3800s (which I love!) with my Beomaster 7000 and thought a nice progression would be the 5702.
They've come from a nice lady who was left them by her late father and are in generally nice condition.
As seems to be the case the KEF passive radiator surround has disintegrated as have the dust caps on the bass drivers.
Fortunately I've managed to source a donor pair of the KEF B139-SP1037 units with the rubber surrounds in very good condition apparently (they are yet to arrive!). I've done a bit of searching but haven't found anywhere that can repair the original radiators, has anyone had any success with this?
As you can see the front grills have had an incident or two (with fetching repair work!) but are structurally solid. I'm going to recover these but would like to source a fabric that is as near as identical to the original as possible. Can anyone suggest any material matches?
I removed the drivers as I'm going to replace the caps in the crossover and was surprised to see a very fine dusty layer of oxidation on the aluminium cage of the bass unit. A good careful bit of brushing and vacuuming removed that swiftly!
The Celestion drivers look to be in good condition so I'm hopeful that these will eventually sound great.
Cosmetically everything is there and will brush up nicely with a bit of TLC and Danish oil - the only slight flaw it that on one speaker the corner aluminium trim and cabinet is a tiny bit bashed! Given the bulkiness and weight of these I'm not surprised that It made contact with a hard floor at some point in the last 40+ years!
I'm looking forward to bringing these back to life and will probably pair them up with my Beolab 5000 which should be coming back from Frede in not too long!
A few more pictures...
Does anyone know what this label would relate to?
Fresh capacitors ordered - need to sort speaker cloth next!
Does anyone know where I can get replacement dust caps from in the UK? I'm pretty sure that 70mm / 2.75" will do the trick. I've found a store in the U.S. but the shipping is £20!!
Well today has been a good day - I've ordered dust caps from speakerrepairshop.com and the capacitors have arrived today from www.hificollective.co.uk (formerly Audiocap).
The donor bass radiators are in with he courier and I've had an interesting lead about possibly getting the original ones restored!
Sadly it doesn't look like I'll be able to get hold of original spec fabric for the frets so will go with another variety - I'm getting a sample of the Jantzen Audio material sent to see what I think.
I'm getting excited about hearing them when they're done!
The label inside is the woodworkers checklist; Sanding, polishing etc....
Ahh - thanks Martin! I like to find these bits that connect with the building of the speaker - it's rewarding to think that the hard work in the factory in Struer hasn't gone unnoticed!
The KEF passive radiators arrived - and as described they're in great condition (eBay plays nice for once!)
As the original fabric is a non-starter I've decided to go with Jantzen Audio fabric in black, a sample arrived yesterday and looks good so the order has been placed!
Very prompt shipping of the dust caps means I've cleaned up the disintegrated muck off the cones and have glued them in place - with a little help from some kitchen items to hold them in place!
I'll aim to get the crossovers done this weekend if I can.
Out with the old sweeties...
...and in with the new
Are you replacing the polyester film capacitors with electrolytics? - Why ??
