Hello everyone,
I have a setup which is exactly like that in the attachment.
I have some questions.
OBJECTIVE : Make this system streaming friendly through Chromecast or Airplay or Spotify Connect or Tidal or Deezer or Qobuz
SETUP
Master : BeoSound 3200 (the Ouverture with a hard drive) with one master link cable going to three devices.
Linked 1 : Beosound 3500 in the kitchen + Beo4 Remote
Linked 2 : BeoLink Active with IR eye (box in the same space as Linked 3) + Beo4 Remote
Linked 3 : BeoLink Passive with IR eye (box in the same space as Linked 2)
QUESTIONS :
How does the single master link become several one. What do master link hubs look like ?
How many masterlink devices can be chained ?
SOLUTION 1 : Easy
The simplest solution would be to plug in an Airport Express/Chromecast Audio/Beosound Essence in the Aux port of the Beosound 3200 and wake it up from any room without fancy apps.
Unfortunately both BeoLinks can't wake the Aux Port on the master Beosound 3200 because they have older versions of the software. So I have to walk to one side of the house to wake up the 3200, then to the other side to start the music in the desired room.
QUESTIONS :
- Do dealers still upgrade BeoLink devices ?
- I have read about BeoLink Active devices updated to SW 1.6, but can BeoLink Passive be updated as well?
SOLUTION 2 : Hard
I don't really know if it would be possible to put a ML hub on one of the ML inputs, and plug in something like a BeoLink Gateway and be able to "see" the existing devices using the Olufsen remote apps ? Then stream to the whole system through Masterlink somehow ?
QUESTIONS :
- Is there a combination of products (ie : Beosound Essence => Beolink Gateway => Current system) that would enable me to stream directly through apps & phones without having to use the Beo4 Remote?
- Would this enable me to bring rooms online without having to be in them (ie if I'm cleaning the whole house).
