Hey everyone, a while a go my BM8000 that had been working perfectly for about a year all of a sudden started acting up.
When I turned on the Beomaster, I heard a loud thumping noise when turning the volume wheel (low volume setting, no input audio signal). Much louder than the regular, almost inaudible ticks when changing volume. Also this thumping sound would happen about every 3 volume steps, not on each individual step up/down.
Then, after about 10 seconds of fiddling with the volume wheel, all of a sudden the house circuit breaker engaged and cut power to the electrical group the amplifier was connected to (no bang or magic smoke, just the circuit breaker cutting power).
Initially I was worried that the power amps had blown, but after checking the BM8000 I found that all fuses were still ok. The darlington transistors and quiescent current resistors measure ok as far as I could check and I couldn’t find any apparent damage. I haven’t switched on the Beomaster since, worried that might lead to more serious damage.
Not sure what to make of this. It doesn't seem likely to me that a high current surge was the cause as all fuses are still intact and the circuit breaker has a 16A limit (no high current devices connected to the electrical group, never had any issues). Any tips on where to begin troubleshooting?
