I have a BM5/BS5 from 2009, on which I got replaced the motherboard about a month ago under warranty. I started looking a bit at the temperature of the BM5, and I found out that the temp often reaches 50 degrees celcius or high 40's. In the log, this triggers a warning and I think this turns on the fan shortly? I have setup the BM5 as a server, meaning it is not going to a complete off/sleep mode. The temp in my house is about 24-25 degrees.
I been wondering if this could lead to failure of harddisk og motherboard due to the high temperatures? Anyone have the same high temperatures as me, or is my fan not working properly?
Some of the log:
12-05-2015 05:52:27 Normal Case:49°C Fan: 255RPM Hdd:49°C
12-05-2015 12:12:43 Warning Case:50°C Fan: 255RPM Hdd:49°C
12-05-2015 12:13:13 Normal Case:49°C Fan: 255RPM Hdd:49°C
12-05-2015 12:15:15 Warning Case:50°C Fan: 255RPM Hdd:49°C
12-05-2015 12:16:16 Normal Case:49°C Fan: 255RPM Hdd:49°C
12-05-2015 12:16:46 Warning Case:50°C Fan: 255RPM Hdd:49°C
12-05-2015 12:18:48 Normal Case:49°C Fan: 255RPM Hdd:49°C
12-05-2015 12:19:18 Warning Case:50°C Fan: 255RPM Hdd:49°C
12-05-2015 12:22:41 Normal Case:49°C Fan: 255RPM Hdd:49°C
12-05-2015 12:23:11 Warning Case:50°C Fan: 255RPM Hdd:49°C
12-05-2015 17:08:47 Warning Case:50°C Fan: 255RPM Hdd:49°C
12-05-2015 20:37:14 Warning Case:0°C Fan: -1RPM Hdd:50°C
13-05-2015 10:33:54 Warning Case:50°C Fan: 255RPM Hdd:50°C
Also find it weird why 13-05-2015 only has 1 warning on a very hot day in the house, when other days have 15-40 warnings!
Regards
Henrik
