OK, I understand that you're focusing on the MPSH54 as the solution.
I checked my parts box, and I have 6 Brand-new NOS MPSH55, which is listed on the same MPSH54 original datasheet from Motorola, showing it as a low noise RF transistor. The only difference between the 54 and 55 is shown as max HFe.
These have the gold leads.
I checked the HFe, and it reads 39. The minimum HFe per the datasheet is 30.
I installed it in the left channel, and the Relay went into protection.
I removed it, and reinstalled the MPSA55 (Hfe 160), and the relay did not activate - but still reading 94mV at TP111.
So, perhaps my MPSH55 HFe is too low at 39.
Can you check the HFe's of your MPSH54's (if that is your shop)?
