I just finished restoring a BM4400, in great cosmetic shape, but poor electronic shape.
I replaced all the components in both completely dead and shorted Output amp stages. Sometimes I am astounded at how these amps get to be destroyed so thoroughly.
All parts are highest quality Nichicon and Panasonic, and the semi's are all original BC5xx, matched where necessary. New original ST TIP142 and 147, and BC139 in the constant current generator.
Basically a complete rebuild from zero, in the output stages.
All main rail voltages check just fine.
It's working almost just fine, with the Bias adjusted to 13mV (across BOTH Emitter resistors = total 0.36ohm) and stable, on both the Left and Right channels.
When I switch on, there's a momentary buzz, and then a low-level-hum, audible at zero volume (not at listening volume), but definitely there.
I checked the DC voltage at the speaker outputs (junction of R286/R47 and R186/R46), and the Left channel shows 52mV and the Right channel shows 56mV.
The RL1 is not activating to shut off the speakers - probably 50mV is below the activation threshold.
I applied freeze-spray on the 0TR100/200 BC139 Constant current generator to see if that would change anything - no change at all.
I also monitored DC voltage at the speaker outputs during power on, and the highest it showed, right at power on, is 700mV, and then decreasing to ~50mV, where it remains stable.
I am normally accustomed to not hearing this buzz and hum at power on (on any amp), and I don't remember ever seeing a speaker output DC of anything above a couple of mV. So this 50mV has me stumped.
Any ideas?
Menahem
