Dear All,
I have a newly acquired Beomaster 4400 that has a problem. The radio isn't giving a stereo output (it is otherwise sonically and cosmetically excellent). With a good strong FM signal (4.5 on the signal strength meter), the stereo light (LED) doesn't shine and I cannot detect any audible difference switching the Mono control on/off. The mono FM sound quality is very good, but I do want stereo.
Looking at the Service Manual, this suggests an adjustment of 3C8 to obtain a 19kHz signal at pin 10 (TP7) on the decoder IC. One problem is that the manual says to do this when tuned to a mono FM station. I don't have any mono FM stations in range in the UK. I do have a DFM and so I set the tuner between frequencies and adjusted 3C8 to get 19kHz at pin 10. When I then tune to an FM stereo radio station, the signal at pin 10 locks to a very stable and accurate 19.0000kHz. However, the stereo lamp still doesn't light and I don't hear stereo audio.
I have also tested pin 6 (connects to stereo LED) and this shows 10.0V whether tuned to a strong FM stereo signal or off signal, i.e. no difference.
Is my improvised adjustment method for 3C8 to get the19kHz reference workable (I don't have a dual input oscilloscope). Does anyone have any suggestion for what to check next?
Thank you.
