If yes, you could take one from PCB 7 (bass/treble/balance indicator). They are just indicator lights and they don't fulfill any other function. Actually you could replace those 3 bulbs with LED's without adverse effect!
The three balance/tonecontrol indicator lamps are used to bleed down the 15V supply when going into standby.
If these lamps are burned the Beomaster can be very difficult to get into standby, because the 15V supply isn't bled down fast enough.
It will just click repeatedly as you hold your finger on the standby pad and go back on without any source selected.
I have removed many LEDs in Beomasters coming in here for repairs and put in the correct lamps.
Good quality lamps will last for decades, but if you absolutely must replace with LEDs, you should also introduce a suitable load (power resistor) to imitate the current flow of the original lamps - and then most of the idea of replacing with LEDs would be punctured in my opinion.
As mentioned earlier, I seem to remember the LDR lamp being an 8,6V type. And yes, it's underrun so most will last a lifetime, they practically
only go bad from rough transport etc.
The lamp is a grain-of-wheat size and you'll be surprised how big a difference a little moving the lamp around makes to the volume etc.
It's just LDRs. yes, but they seem to be matched. You can't always just take an LDR from one case and move it to another without also moving its mate in the other channel.
Probably why this module was not available in separate parts - only as a complete and sealed unit.
I will be happy to dig around in the dungeons for a good used LDR casing if needed.
