Aad Jansse wrote:
As to the scope:I used once, a century ago, a scope, but my borrowed one has an usermanual in German which language is much les than my English.
What I actually want to know: could I do any harm to the circuits when I put the probe on whatever place in a pcb and then start pushing and turning knobs and buttons.
No worries. Provided that the oscilloscope still works as it should, you can't damage anything on the circuit.
One important thing you have to keep in mind:
The ground terminal on the probe is usually earthed !!! So, if you carelessly attach it to the wrong part on the 240V side, you'd trip the RCCB (ground fault protector) in your house.
Just steer clear of the 240V side of your device. You'd need a 1:20 probe or bigger to measure anything on the grid side of the circuit anyway.
If I were you, I'd familiarize myself with the scope function on some other signal before starting on the BM1900 (e.g. the signal from headphone connector of your PC/notebook that will supply the signal from the signal generator software). Google translate will help with translating the labels on the scope and you should be able to find quick tutorials on how to use a scope on the net.
