BM 1000 Mexico
About 1 year ago I bought in DK a BM 1000 together with a BG 1000, these are the same models as the ones I bought new in 1969, I bought these only for sentimental reasons 😁. I went to DK in May this year to bring both items to Mexico. My son (now living in DK) fell in love with the BG 1000, so I had to leave it in the father land. So the only items I had to bring over here was the BM 1000, a Master de Luxe Present 608 a gift from Martin (more later on this one)  and some cartridges from Axel and 1 bought locally in DK.
Here the cleaning story of the BM 1000.
First of all the number, (Martin always want numbers)
The BM is functioning OK, but no lights, so I started taking it apart for cleaning and components needed for rebuilding. Bottom cover comes off with, unscrew 2 screws one side, loosen 2 screws on the other side, pull the cover to the side and lift it out, save the 2 insulation strips. the top cover comes off by unscrewing 2 screws on each side, through holes in the bottom frame and one in the middle of the bottom cover.
Turn the BM around lift of the top cover, here also the the knobs off, pull off, no screws to hold them.
Frequency scale comes off with 2 screws
Then the piano keys came off, also 2 screws
Dusty and dirty.
Both side keys out
The scale background comes out, bending the 3 clips and lift it out, fumbling a little.
To get off the front face pull off the 2 clips. red arrow.
And then unscrew the 4 screws 2 right side 2 left side
Then I took out the lamps, here a pic with scale and different items, the black piece above the lamps is a reflector, remember the placement of that one.
I found out, that the bottom frame with front cover also had to be dismantled
As the keays was working sluggish I wanted to give them a good clean, so the scale drive had to come out too, 2 screws front and 2 screws in the middle frame wall
The big cap comes loose with 1 screw from the bottom, lift it up without braking any wires
To lift up the switch assembly, I had to unscrew 2 screws at the bottom and take out the sidewall, transformer side, unscrew 2 screws holding the transformer from the bottom, the switch assembly has 2 pegs sitting under the inside division wall, loosen 1 screw from the bottom, lift it a little and the assembly comes out, be very careful not to break any wires doing this
Look at all the dirt in there, here the other side, this one comes out easily, just unscrew 2 screws from the bottom, wiggle out the assembly, 👍 wires !!!
All the innards was dirty like this
I normally clean it all with a brush and Isopropyl alcohol, but this time I selected to do it with a spray bottle (one of these with a finger triggered pump, that comes with detergent in it), I cleaned the bottle and filled it with IPA, and then sprayed off all the dirt, sprayed a lot into the switches and potentiometers, when good wet I worked all the switches off and on many times, and then a lot of IPA again. The main PCB got a spray and left it to soak a couple of minutes and then sprayed it again until clean. All clean. Give the switches a small drop of grease before attaching the keys.
Now ready to assemble it all again, I thought I could put in the piano keys just like I took them out, but no such luck, I had to attach them one by one
To get them off the steel angle, press down and out on the middle peg (red arrow), and they come off easily, clean,  and after positioning the steel angle its easy to assemble one by one. I gave the middle pegs a drop of oil before attaching
All in and ready to connect and adjust the 30 volt feed and the idling current.
The 30 volt feed was down to 24 V and the idle current down to 5 mV, adjusting was very difficult, but after moving the trimmers a bit I got it. The trimmers will be changed with new ones later on, as will lamps and caps., after that I put in the stereo decoder and the rest of the covers, played some different FM stations, checked all functions and switches, had to readjust key positions, but it all works, then connected a BG 1202 and that too worked as it should. Finished
Connecting my type M speakers I saw this little reminder, and that made me think of the new devises you buy today, with some hundreds of watts displayed
Here the other (older) BG 1000 (Piaf (Jeff) has one
Will come back here after changing components.
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
Nice to see you back at work Søren.  It is fun to restore old components we have a history with.
Thanks John, took some time to get the spirit again. More to come
Retired
Rock and Roll music
Collecting Vinyl
Looks great, :)
Dont the or or less the same work myself on several BM1000.
Kind of special machine to re-assemble...
Its a joy when they are working. IMO they used better components back then, Except for the lamps everything still works on this one, no scratching potis or switches after cleaning, and most of the old gray caps still within limits. Do you change all electrolytic caps and all lamps on yours when repairing, or just the bad ones.
Retired
Rock and Roll music
Collecting Vinyl
I have  too many of the BM1000´s ( need to get rid of most of them, but they are very difficult to sell in Sweden ) that I dont do total recap.
I recap powersupply and sometimes the speaker output, do error check, some very few electrical repairs, change bulbs, general cleaning, cleaning and oiling tuner thread and the mechanics involved, clean potentiometers., and then do good listening test to check the quality of it.
Some are in good shape inside, and some BM1000 have been way worse then the images you posted, so the cleaning have taken very very long time.
Martin wrote in some post that the grey caps seldom is bad in this model.
Checking power supply voltage was a good tip though...
Have had a busy summer, so I am still working on my reel BC1200, and after that I will dive into the BC2400 deluxe. both of them will have all rode caps replaced by the time I am finished with them
Tonight I start the electrical adjutments on the BC12000, kind of hazzle as the eq adjustment is not trim potetionmeters, you have to change components..
C
I always check the voltages and adjust if necessary, and if I find one bad electrolytic cap, I change them all. When you start on your BC 2400 de luxe please post, I have a BC 2000 RtoR waiting for TLC
Retired
Rock and Roll music
Collecting Vinyl
Sure I will :), that will be fun...but I wont start on the BC2400 until september.
Christian
Now I got the parts from Martin, caps and lamp kit, so i took the BM 1000 apart again, and changed all caps that Martin provided.
I am a little surprised, for the 3000  uF he provided 2200 uF, I wonder how this will work, but as I know Martin I put them in where they belong, and tomorrow I will test it. As usual it all came with good installation instructions
As I probably mentioned before, this is to complete the very first B&O system I bought back in 1969 and later sold to buy a car. The Beovox 1000 are still missing, but I will get those too someday.
Old caps out, new in, and some more cleaning was possible.
Here is what came out, also from the multiplex adapter, more to come
Retired
Rock and Roll music
Collecting Vinyl
Great to see you back restoring.
