BL 3500 Issues
Greeting everyone...
So, here it is.  Setup is a BS1 (Option 2) in Main Room with BV4-50 and BeoSound 9000 (Option 0) via ML, as all speakers (BL1 frt, 7-4 ctr, 6000 rear and subwoofer) are connected to the BS1 in the Main Room.  Additional I have a BL 3500 (Option 6) original SW1.0 setup on my outside porch via ML.  Upon first setting this system up if I pressed TV on my Beo4 remote while on the porch the BL3500 would wake up and the audio from the whatever was being watched in the Main Room could be heard out on the porch.
The BL3500 was disconnected for sometime while some remodeling was going on and cables were being pulled through the walls to its location.  In addition the BL 3500 has been upgraded to SW2.1.  Now with everything setup again if I perform the same function the BL3500 (Option 6) wakes up and displays TV yet there is no sound.  CD function still works like it always has though.
Am I missing something, I don't recall ever doing anything more then pressing TV on the Beo4 remote.
Thanks,
Hiller
Try pressing AV-TV on your Beo4. It should link TV in audio mode.
hfat
