Hi everyone!
I've been trouble shooting my old CD 5500 that did nothing when plugged in. I traced it down to R11 and R12, one measures in the MOhms and the other is open. As I can't find a fuse I can only assume that their purpose is to act as such.
My question is what to replace them with to get the same behavior in over current situations, i.e. to work like intended?
Now, before you come suggesting there's a reason that they blew and I should find out why (rightly so!), I did actually short them out and monitor the current draw and everything looked completely normal. To give you the background, I was using the machine to reverse engineer its datalink behavior on start-up to mimic that for a gadget I'm building and I probably screwed up and shorted something.
Anyway, advice would be highly appreciated!
Thanks!
/ Johan
