chartz wrote:
Were the output trannies fried?
Hi Jacques,
0
0
1
147
842
Compass-NAV inc.
7
1
988
14.0
Normal
0
false
false
false
EN-CA
JA
X-NONE
Unfortunately yes, two TIP141 on the right
channel that I find very strange by the way, but I think I have pinpointed the
problem. You see, I consulted the site many times to find the common anomalies
for this amplifier before beginning the restoration of mine. In all cases, some
output transistors were defective and that, in my opinion, it's really not
normal, because this amp is very well protected at the output stage. I have
never seen, in all my restorations, damaged output transistors without any
damage in the upstream output circuit either through abuse, "visible"
component failure or something else... In my case, everything is good, but two
failed TIP141 ... ??? As you know, the number one cause of chip failure is
heat. I very much suspect that the heat
dissipation from the back plate, where the trannies are mounted, to the
heatsink is very bad because of the modular design. I do not want to dwell on
it here, but you can see the details on my post here: /forum/imported-unmapped/bm4400-restoration-in-progress
