Beovox CX100 Plastic Speaker Grill Repair / Replacement
I have a set of white CX100's that have broken tabs on the woofer grills. The larger middle tab and smaller tab are broken. Also, one of them has a broken thin cross-member going to a front corner. Is there a way to fix these features of the frames, or are there factory replacements available?
What about 3D printing?
Guess these are the files you need.
Maybe you know someone (who knows someone) who can print them for you?
Should only be a few $ of material
https://www.thingiverse.com/thing:365459
I looked into it, but it is somewhat expensive for the better quality prints and materials. The parts would probably be more brittle than the originals in a couple years.
Black or white?
Can't you glue the broken tabs? I have done that many times.
White. Some of them are completely missing. One grill has a missing section on the thin member that forms the triangle on the side.
Here's what it looks like.
The white ones always tended to become more brittle than the black.
If you fit black plastic frames behind white cloth they will shine through, but you could paint them white.
