Beovox Cona left out doesn’t work
I just bought a Cona that should add some more bass to my Beocenter 9000 with CX100 speakers. The problem is that the left out doesn’t work, no sound at all.
I have opened it and everything looks ok. No loose wires, no leaking capacitors. The Cona was bought privately online and the seller said it worked perfectly, but...............
/riis
You were right sonavor. It was a break in one of the DIN-plugs in the Beocenter. Thanks for your advice.
/riis
