Beovox C30 - Rubber Woofer Surrounds?
Hi all
I have a pair of C30 loudspeakers. The woofers appear to have surrounds that are quite different to the usual foam surrounds of other Beovox woofers. They feel and look like rubber and there is no deterioration at all in the material. Does anyone know if these drivers were fitted with rubber surrounds at any stage in their production life?
I've enclosed a photo.
Thanks!
The woofer in the photo looks perfectly original for this Beovox model.
Thanks Martin 🙂
Do you know what this surround would be made from?
It looks and feels exactly like rubber and nothing like the foam used in other Beovox models.
Sorry I missed the link :
https://bekent.dk/selvbyg-hojtalere1/hojttaler-reservedele/kantophaeng-bang-og-olufsen.html
regards
Lassfi
