I have just picked up a pair of Beovox 5000 Mk I, Type 6206 in quite good conditions. Practically no scratches, only e few spots, probably from water. Would be no problem restoring the veneer.
But I have a few questions:
The speaker cables has been cut; they are only around 2 meters long and as normal they look very "smokey" / dirty. And as they are relatively thin, I'm considering being able to connect the speaker with thicker cable. I'm seeking information on the following:
1) Replacing the cable with a new cable of the same thickness.
2) Replacing the cable with thicker cable. This probably require, that I drill the hole a bit bigger, to accomodate thicker cable.
3) Install high-end connectors, that can accomodate thicker cables, spades, banana connectors, etc.
Would drilling holes for such connectors been considered demolishing a pair of vintage Beovox 5000 speakers?
Additionally I would like know, if, when I have made access to the inner of the speaker, should replace the capacitors. Is the cross-over constructed in a way, that makes it easy to replace the capacitors?
I look forward to - as always - get experienced answers from Beolovers.
Best regards
Nis
