I purchased a pair of Beovox 4702, one of the bass elements were unusable, rotten membrane. Is it possible to replace this element in the 4702 with the bass element from Beovox S30? Seems to me they look almost quite the same.
Beovox 4702, replace bass from Beovox S30?
Some Beovox 4702 (and 4703) came with foam surrounds (that rot), but a few had rubber (that doesn't).
Some speakers even came with mixed foam/rubber woofers.
I suggest you check the other three woofers.
S30 woofers are very different and can't be used for the 4702 but I have some good
used original 4702 woofers with rubber surrounds if you need. PM me for details.
BTW : The magnets on the woofers of the 4702 and 4703 should be glued like the S45 and P45.
You can read a lot more in the forum about this.
I'm interested, tried to PM you.
