On the Web, I have located a pair of Beovox 3000 type 6220. Does this old type of speakers use foam based woofers? How do one remove the front to be able to view the speakers? Are the speakers mounted from the front?
Best regards
Nis
Best regards
Nis
They are rubber based and actually some of the better sounding Beovox speakers from that period. Wonderful bass response and still today it's hard to believe that they are merely 2-way speakers.
The front is either clipped or velcro'ed on, I don't remember, but they come off quite easily.
The drivers are mounted from the front.
Hi Martin and others,
The text on
The Beovox 3000Mk1 is the version with two small tweeters side by side, and is very rare.
The Beovox 3000mk2 is the one with a single tweeter, and is only slightly more common.
They sound very good, but the 'sweet' spot is quite small.
Beovox4000 also had 2 versions, but I'm not sure they had seperate B&O part numbers, and again this was related to teh number and position of the tweeters, and if anything these are even rarer than the 3000's. Methinks that people went for the Beovox 5000 instead.
So the final conclusion concerning the pictures on link must be, that the pictures seems to be wrong or at least not include the two-way version.
As I haven’t bought the Beovox 3000 I located on the Web, I’ll try visit the person selling the speakers and get some pictures of them, then and try figure out how to upload them.
🙂 Nis
Got the following picture of a Beovox 3000, type 6220:
Regards NIs
Yes, that's the type I've seen.
