Hi!
I have a bit of a problem with one of my Beovox 1500 speakers. They have an adjusable midrange switch, with five different levels. Two of them doesn't work, level three and four, and the midrange speaker goes silent when I switch to either of those two levels. When I yank the switch the sound comes and goes, as if somethings loose inside. What do you guys think it is? What's the easiest way to go if I want to have a look see inside the speaker? Screw loose the woofer speaker?
