Beovision Avant 32 CRT
I did! And the sound is great. I love the motorized stand. Has anyone who has used it for just music done anything about possible burn in for the CRT?
Sorry for my English, i don't understand "burn in" but i think you want to use the Beovision just for the music without screen, it's possible ,you can hear spotify with apple TV and airparrot 2 ,with itunes , with your TV (Channel music) and other devices ,you must use your Beo 4 and push TV-AV-TV ,your TV screen close and you can hear all input.
I hope i can help you.
No problem, "burn in" is when a picture is left on a screen for too long, and it the phosphor pixels keep a part of the image "burned in" to the screen.
I will try the tv-av-tv.  I had tried to find the p-mute function on the Beo4, but appearently my model doesn't have it.  Also, I had an iPad hooked into the top ports on the set, and selected "camcord"  and after that the set would not respond to any inputs on the remote at all.  I had to unplug it.  Anyone else experience this?
Hi,thank you for the translation.If you want to find P-mute ,you need to open the hidden listen in the Beo 4.Push both red button and list together and after choose ADD with the list button ,if you use an Ipad or Ipod on the TV ,you need a special cable by Apple to transfert in analog video and not the cable for the numeric.
