Beovision 9 Screen Removal How to- but problem not gone away
This is the problem (black strip on the left image) but if I apply pressure to the area I can make the strip temporarily disappearSo I decided I would remove the screen and reseat the ribbon cable- it hasn't worked so any advice welcome.  In the meantime if anyone else wants to remove their Beovision 9 screen here's how to do it.
Removing the plasmas screen from the Beovision 9 is relatively straightforward – but you need two people to do it due to the weight.
1 Remove front frame- it comes off with a good pull (start at the corner)
2 Remove the torx screws holding speaker panel – pull panel off carefully and disconnect the center speaker (2 wires)
3 With one person holding screen from the front go to back of the TV and remove the 4 black plastic caps to reveal the 4 bolts that attach TV screen frame to TV cabinet then remove the bolts (once undone the TV is then only held on by the three adjusting bolts – see red circles)
4 Screw the three adjusting bolts (red circles) clockwise to release screen from TV cabinet
5 Leaver screen forward carefully and disconnect the 3 leads (yellow circles)
6 Remove screen from the cabinet
Once removed, taking the screen frame off is pretty easy and it’s clear which bolts to remove.
To remove the rear case remove all screws around the edge- I think there are about 28.
Reinstallation
The tricky part is getting the three frame bolts (red circles) to line up with the holes on the cabinet. I looked through the holes at the back with a torch to see when they were lined up.
0 0 1 210 1198 Westcliff-on-sea, Southend-on-Sea SS0 0BU 9 2 1406 14.0 Normal 0 false false false EN-US JA X-NONE
There are two adjuster bolts (green circle) that the Screen frame rests on, these can be adjusted down to give a little more clearance when reinstalling if necessary- just remember to screw them back up again
Mind the dust!
Even more dust
The end point.  Orange ellipse is the Problem connection point but reseating didn't help.
My question is using a Panasonic screen as a replacement which I can get hold of.  I know the model number TH-50PF9, but will there be any set up issues as I've read others have had problems connecting it up to beosystem 3 and it not being recognised?
Many thanks to you all
You could replace the entire panel and maintain the D-board and boards around the input (DVI etc). Then the panel will certainly be recognized.
But the main problem will be the colourmanagement. The BV9 has a calibrated panel which is adjusted with the help of the froant camera (mk3 or highr). I don;t know if the camera if fully capable of adjusting the colours (greyscale, white point etc).
Maybe only changing the DVI module could be enough the let the panel be recognized by the BS3. Your computer will recognize the B&O panel as a B&O Dx version.
Thanks I was hoping I could repair it by selecting the appropriate boards.  For replacement purposes I'm looking at a TH-50pf10, my screen is a TH-50pf9. Will the display from the pf10 work OK with the relevant boards from the pf10? My BV 9 is a mark2 so doesn't have the camera so avoids the extra complications (?)
Sorry meant to say 'will screen from pf10 work with boards from pf9'.
Hello,
Know that is really old post, but do you know the replacement screen type? Could you please send it to me?
Really keen to know if you can replace the screen with a Samsung,Sony,lg ...etc
1. What functions would I loose.? Turn, stand function
2. And do you just need a dvi to hdmi lead to go to new screen & power?
3. Will the menu still show as it does now, or will that be from the new screen?
As you can see from picture my screen has lines on it at bottom but if I pull white plug from bs3 it disappears .....could this been cable plug needing re seated in monitor?
Faint white lines
Only appear on initial turn on.
Unplug white plug and re plug they disappear , there s not any other issues with screen....been advised to scrap...seems a waste...when if possible I could upgrade screen with 4K/uhd.
Well I have started...gone for complete strip out... and de-dust
Various stages
Removed HDR ....not needed
Beosystem removed and in safe place
As for what is in it....the cost new was for design..MDF
Screen was a dead weight...nice new slim oled....hopefully to be fitted
Hello
After a day of cleaning the carcass I managed to set up beosystem 3 and carried out a test regarding ir on bv9,
Used a 32 " Samsung and it worked perfect nice crisp image😁
Think this is going to look brilliant when complete.
Will need some frame work inside cabinet for new screen.
Wonderful project! I'm curious about the final result. Please keep on posting your construction steps and photos. :)
Small update:
1st fix off hdmi lead into cabinet.
Foam inserts for new panel to rest on, trial and error may need to add or remove depending on panel😮
All glued in place
