Beovision 8 masterlink socket.
Hi all, I am new to the forum as I have never had a problem before. I have a second Beovision 8-32 that I have just fitted with the freeveiw module but I cannot get the masterlink socket to connect my Beosound overture. Does anyone know what the settings  are in the onscreen menu please.
Does it have the MasterLink module built in?
That could well answer my question, my original 8-32 was ordered new & B&O set it up for me. I now presume that my 2nd set hasn't got a ML module, are they still available?
I am sure a call to a dealer will get you one.
But there may be cheaper integration approaches.
What sources are youu wanting to access across the ML ?
If i understand you right you have the ML socket on your bv8-32 ? if so you also have ML module,  but you maybe have to set v.option 2 on tv (default is v.option 1 and then tv is not listen to audio commands from remote)
Hello, i need a module ML for my beovision 8 32. Do you have ? Thx
In order for the Ml module to be active, you will have to disable the power saving function in the TV.
That might be the reason it isn't working
