Hi all, I am new to the forum as I have never had a problem before. I have a second Beovision 8-32 that I have just fitted with the freeveiw module but I cannot get the masterlink socket to connect my Beosound overture. Does anyone know what the settings are in the onscreen menu please.
Beovision 8 masterlink socket.
Does it have the MasterLink module built in?
That could well answer my question, my original 8-32 was ordered new & B&O set it up for me. I now presume that my 2nd set hasn't got a ML module, are they still available?
If i understand you right you have the ML socket on your bv8-32 ? if so you also have ML module, but you maybe have to set v.option 2 on tv (default is v.option 1 and then tv is not listen to audio commands from remote)
Hello, i need a module ML for my beovision 8 32. Do you have ? Thx
In order for the Ml module to be active, you will have to disable the power saving function in the TV.
That might be the reason it isn't working
