Beovision 10-46 replacement display?
Hi, the T-Con is separate from the LCD Panel 6 screws, not a problem to replace but finding one is, usually from a 10-46 with faulty chassis!
BV 10-46 MK1 has a diffrent Panel Type as that from a MK2 this means a different T-Con,
I have a BV10-46 MK1 with faulty T-Con but I only managed to buy a T-Con from ebay for a MK2 BV10-46
MK2 has 3 HDMI connections
BV10-40 T-Cons can also use T-Cons salvaged from BV 7-40s
Regards Douglas Cunningham
Hi Douglas, please give me a note if you want to sell your T-Con MK2 🙏🙏 Thanks . regards, Tran
mobilett wrote:
Has anyone figured this out yet? Or found a panel that works? Is the backlight control really needed/important?
Sadly it really isn't worth the effort or cost, sad as this sounds. You'd be better trying to source a pre-loved BV11-46 or 14.
But.. is it really that hard to strip the entire LCD assembly from the BV10 and replace it with a brand new LCD/OLED? From
Hi. What dealer ON eBay had the T-con board for BV 10 46? Regards Jesper
What are the symptoms of a faulty display or a faulty T-con board? My 10-46 has tarted to behave strangely, the picture freezes and fades to grayish large dots in the upper right and lower left corners. Could that be due to a faulty T-con board?
Bottom Line: My panel is gone. Took about a week to die from frist symptoms. Scart inputs still working, but of little use in todays digital world.
Sverre
Sverre
I'm also interested, so if anyone go a solution - i'm all ears :)
Best
/Jesper
