I have been hoping to acquire one of these BeoTime clocks for some time, but all the ones I have found have had a couple of damaged areas and the price was excessive (in my opinion at +$400) I finally found an undamaged clock but the seller insisted on $1,200 so that didn’t go anywhere. Then I found one on eBay at a reasonable price and I purchased it.
Perhaps I should rephrase my question. From all the photos I have seen on eBay I assumed what I was seeing was an actual Beogram 8002 platter with the raised rubber bits to support the record that B&O had converted into a clock adding the Bang & Olufsen under the 12 and BEOTIME over the 6 and putting a battery operated clock movement using the center hole in the platter.
What I have is NOT a Beogram 8002 platter, instead it is a12 inch aluminum disc which has black printing that very much resembles the pattern on the Beogram 8002, but this is only printing, although it is raised so you can feel it with your fingers.
The hands are exactly like all the B&O clocks I have seen, heavy square black hands with red tips and a red second hand.
There are no markings of any kind on the reverse.
The clock came in a heavy fitted box that was made for it, holding the clock by the German movement. The box has a white sticker with bar code and number: 36588330, Beotime clock Bang & Olufsen Madison Ave.
Does that help?
Jeff
