The device is 1992 Beosystem 2500.
I have noticed that the FM Tuner is much quieter then CD at the same volume settings - when the CD volume is set to 30 it is about as loud as FM Radio at 50. Is this normal?
Also - and I yet have to confirm this once more - it seems that the tuner sometimes doesnt work immediately when the beocenter is turned on, it once took few minutes for tuner to start playing. This made me suspicios that some of the capacitors are bad - is this common on this devices?
And I have common problem - tape deck doesnt work. I will disassemble the beocenter to check for the common problems found on this forum - fuses and belt. Anything else to check?
