My Ouverture will not play tape, the seller i have buy it from says they not have uses the tape function in many years, the problem is if i push play, rewind, forward than i i can only hear a "click" sound no movement in the cassette or any of the tape parts below the tape.
Do any have a solution on how to fix it? So i can use the tape function.
