Martin wrote:
Reading about the mechanisms, it is my impression that the CDM4s are a lot less error prone - save for the infamous capacitor, but that is at least an easy fix.
Far be it from me to talk you out of it! Sound quality is something like a religion to some people -- in fact for me too. But in the end it's a very subjective thing and you should go with what suits you best.
The CDM12 Industrial has a very good reputation, so it's nothing to look down at. It has a 3 beam technology, which makes it faster but of course also more error prone when it starts aging. The simpler single beam CDM4 doesn't exhibit that ailment.
Martin wrote:
manfy, I saw these notes in that service manual too but could not make sense of if anything needed modification or not. Looking at the companion circuit board for the CDM12, it is marked as supplying both 5V and 12V via the P200 connector that goes to the board behind the CD. So hopefully it should work with Ouverture CDM12 -> Ouverture CDM4 as well!
That's easy to verify. Page 15.1 of the service manual shows that the PCB89 (CD interface) has a connector P67 has -5V on pin 1. This voltage is not needed on the CDM12 mechanism, but it IS required for the CDM4. (On the CDM4 this connector goes to the servo board 8.)
If you can measure -5V on your P67 between pins 1 and 3 (GND) then you're good to go.
If you measure 0V then you need to look at the power supply (PCB 12) and you need to find the location of those components 12R113, R23, C61, D7 and TR2 and add them manually.
But to be honest, I find it hard to believe that B&O really skipped those components for units shipped with CDM12. They would save only 10-20cents per PCB, but add the cost of creating a second board version, add costs of stock keeping, etc. etc. That sounds really stupid - but well, who knows!
In any case, you have to check that you have taht -5V supply on connector P67.1. The CDM4 won't work without it.
