i'm new here (sorry for the first post being a technical question)
I have the following problem:
<< rewind ist not doing well (changing speed, in the middle of tape getting stuck)
>> fast forward is running perfect.
> play as well
if i turn sides it is still the rewind that is problematic.
if it gets stuck, the head plate is still in the upper position and it is not possible to take the tape out.
switching the overture off on does not help.
if i try to play, fast forward, rewind: it makes some clicking sounds and i can hear the motor running (capstan is spinning but the rest not)
i pushed the heads plate down it went to base position (i could take the tape out)
but it was still not running (clicking sounds and i can hear the motor running, capstan is spinning but the rest not)
I disassembled the unit and dismounted the tape deck: after spinning the flywheels manually in the right direction some of the mode selection gearwheels (i don't know hot to call them) jumpt back in the right position and the tape deck was back to operational mode.
but the problem with rewind is still there (i'm sure if i let it running it will get stack again)
how can i solve the problem?
Best
Dim
