Good evening.
I hope this is the correct forum for this post.
I just received a reasonably well loved BeoSound Century Type 2655 S/N starting 11, so 1996 I think, that I purchased from an auction site locally here in New Zealand.
It was as-is-where-is, so I expected some issues.
Other than a few of the keys rotating, door needing a bit of work, and tape drive needing a good clean and a test, it all seems to work, other than... no proper sound out of left hand speaker group.
If I select Sound, and drive balance all the way to 6 to left hand side. Tweater is very, very quiet, crackly, and woofer is doing nothing. As soon as I get to 5 on balance, the right hand kicks in and sounds fine. If I balance fully right hand, it sounds as one would expect running everything in the right hand side. RH side seems fine.
I have a service manual, and I can trace the cables I think. It looks like I'm staring down hauling out everything to ensure the cable is securely fitted as it's on the rear of the board.
Any other ideas of where I should be turning my attention to?
Kind regards,
Mark
