You're welcome 🤒
I change them regularly as they are only a few euro's. I don't know how long it will last when you bend them.
You're welcome 🤒
Sorry for bringing an old thread back to life. But I think my Beosound 9000 rocker arm is also bent. Where can you purcahse these from Beobuddy? online? or only from a B&O dealer?
I think I can add some info to this. When I removed the rocker arm from my unit I showed it to my friend who is a structural engineer. He laughed and said there was no way that part would bend in the unit after looking over the mechanicals. I purchased and installed the new part anyway and problem solved. I also compared the old to the new and didn't notice any difference.
I am now looking at another new rocker arm compared to the old defective one. They line up perfectly in all respects when on a flat level surface. The small rubber sleeve, part # 3333022, Damper f/rocker arm, which is number 46 in the diagram in the MKIII service manual is visibly worn, but hard to notice. Upon further inspection with a magnifying glass and xacto-blade, I can see that it is torn and there is a small flap that exposes the bare metal.
My guess is that over time the metal edge of the slot on the arm that the rocker slips into cuts into the rubber and there can be some sideways movement. This causes the torn rubber to move out of the way and expose the metal below, which is enough of a height difference to cause the mechanism to retract less than it should, and then scrape the top of the CDs. I don't know where the contact is made that causes the clunky noise we hear. I'm sure someone with much more experience has identified the point of contact.
I purchased a couple of extra rubber dampers for the future as they cost nearly nothing. I suppose one could just rotate the damper 180 degrees on its shaft and then glue the torn section (which is very small), but the part is still available.
Thanks Bill, that sounds plausible to me. Where can you buy the rubber dampers from?
Guys,
could you make a photo of that damper ?
if you check the first page of this post there is a picture of the rocker arm by itself and the rocker arm installed in the 9000. The damper is the "clear" or white piece of tube on the left side of the rocker arm at the rear in the photo of the rocker arm. In the photo of the rocker arm installed it can be seen under the red arrow marked "handle". It is #46 in the exploded diagram from the service manual.
Dear sir I have the same problem when the cd changer move to another cd I can hear rubbing click sound can you please kindly send me where did you bought the rubber number 46 ? Part 33333022 please my email is sam97can@yahoo.com thank you
