I just bought a Beosound 9000 Mk3 and noticed that sledge touches the back of the CDs when moving from one CD to another one.
I found nothing related to this in the B&O service manual. There are some posts in this forum but coudn't find any other solution than visiting the B&O shop (which I would like to avoid).
I have removed the CD clamper and had a look at the sledge looking for some screws to adjust the distance to the CDs but found nothing.
The sledge doesn't touch the CDs in horizontal position on a table but it does on the vertical stand. I saw that the CD mechanism is hold by 4 springs with foam inside so I assume that on the table the weight of the mechanism is enough to compress a little bit the springs increasing the gap.
Is there something wore out? Is it posible to adjust the gap in some way? Any suggestions?
Thanks in advance
Alfonso
