The sled moves freely so I can get to the plastic cover. It does not seem to want to come off. Do I need to remove the back and unscrew the plastic cover or should it just pop off from the front?
Beosound 9000 Mk1 Dead
its screwed on from the fronr if memory serves me correctly you can gain more access undoing the four screws on the transformer.
Doug if you go to safari and type in beosound 9000 service its the green cover manual with your type number on it, its from elektrotanya where you can download it or if you are a silver member you may be able to get it from this site.Regards
If TS has 10V AC from the transformer, then there is no need to take out the small PCB beneath the aluminum plate.
It needs to have 5,3V around T37/(T10 on newer boards).
HI i take you mean 3TR37 so you are checking sipply to the power switching PCB33 if i have understood your comment correctly i bow to your superior knowledge i was aiming at certain trees in the woods not looking at the overall pic so to speak thanks for pointing that out
regards Maurice
I have 13vdc on the top and bottom leads of TR37.
Hi, was wondering if you managed to fix this. I picked up a dead beosound 9000 yesterday and this thread seems to be the only infosource on this model. Would love to get some tips on where to look for.
What if the stand-by led now work again , and radio work but not CD and display ?
You will need to provide more information about the fault you have on your BeoSound 9000 and what "Mark" or "Type" number it is?
I suggest you start a new thread with full details of your problem.
Again, please provide more detail in particular which version of BeoSound 9000 you are talking about.
You can only receive quality answers if you provide as much detail as possible..
