I have recently become the owner of a Beosound 9000 Mk1 (Model 2523). It has very good physical appearance but is completely dead on the electronics. I have opened it up and found this:
The standby light is not lighting.
The transformer is putting out about 10 VAC
The 3 fuses are all good.
There is about 4.8 VAC on BOTH sides of the fuse "sockets". That seemed strange to me.
I followed the trouble shooting guide for a Mk3 and removed several of the ribbon cables. I did not get any standby light. Was I to remove each one individually and then reinstall it or pull the all off? I did each one individually.
I suspect that there is no DC voltage being created anywhere on the power supply but I do not know where to take test measurements. There appear to be enough differences between the MK1 and MK3 that I could get in deep trouble without the right manuals.
So my options are:
1) Hang it on the wall and let it look pretty. Tell stories of how it would operate if it was not dead. That would make me sad.
2) Hope for a miracle answer and simple repair from this forum. That would be great.
3) Send it to B&O and spend the kids college fund getting it repaired. That would make me poor.
4) Some option I have not considered?
Thanks!
