Hi All,
I've recently purchased a faulty Beomaster 5 and Beosound 5. The motherboard in the Beomaster has failed. In my testing, I've been trying to see if I can use the Beosound 5 just plugged in to a laptop via DVI and USB.
However, it's not recognised - either as a monitor or as a USB device. Is this expected? I would have thought it should be recognised as a standard monitor and USB device...
I'm thinking the Beosound 5 is faulty too?
The power supply in the Beomaster is working fine - I'm seeing the correct voltages being sent to the Beosound.
Thanks,
Andrew
