Just thinking as spotify doesn't work with Beosound 5 is there any way to plug in my iphone to beomaster 5 to play spotify through it ?
Please have a look in the Userguide/page 25.
Sorry if this something you already know but Spotify does work on BS5. It's not as fully featured as on iPhone/iPad. But you can make playlists or save albums as playlists on your idevice and play those directly on your BS5.
if you meant it's not full blown Spotify functionality then of course you are right.
in other worlds I don't need Beolab 20 anymore
what a CON company B&O shocking
Beo Moment is poor as well
There is another thread on the subject of the search function (and top albums and tracks functions) having stopped working on BS5. If these reappear through an update then I think the Spotify functionality is ok and back to normal. If not then I will be very disappointed in B&O. Time will tell.
Sorry - but what has a (partly) missing feature of the BM/BS5 to do with the need for a speaker like the BL20?
Search function (and top albums and tracks functions) having stopped working on BS5
I think this is not Argos quality player but if I'm not able to do search etc... what the point ?
And my question is what should I use my speakers(Lab20) with ?
Not great comments about Moment as well ....
On my A9 I can easily hook up ipad and play whatever I like
On BM5 I'm limited to my collection , radio maybe 10% stations working
yes but how long do we have to wait for that ???
