I have a Beosound 5 and a BV 10 in the main room. In another room there is a BeoSound 3000. I want to listen to N.RADIO on the Beosound 3000. What are the right option settings? I wanted to put the BS 3000 on option 6, but it doesn't have an option 6…
Beosound 5 and Beosound 3000 in other room
A.OPT 6 should work on your BS3000, but maybe you have an early one? Does it have the small clamper or the large one?
Maybe a sw update will help...?
Stefan
It has a large clamper and recent software because it supports N.Music
You will need to put your BeoSound 5 into A. Option 0 assuming it's still connected to the BV10 making sure to setup the BS5 to handle N.Music/Radio commands as just that and not the CD or Radio buttons. The BV10 then should be set to V. Option 2. From there connect your BS3000 in the next room and set it to Link Option 6. You will need to also add the soft buttons to the list menu for N. Music and N. Radio if you haven't already done so. Now in the link room using N.Music or N. Radio buttons should pull the content from your BeoSound/Master 5 into the BS3000 provided you have a version with the updated SW and Hardware to handle it.
Thanks All, Have done all the above, except my BS 3000 doesn't accept option 6. Only 0, 1 and 2. Anything else I can do?
Sorry - you can't set an audiosystem to L.OPT !
Stefan
So how Can I use a BeoSound 5 with N.RADIO in one room and listen to N.RADIO on the BS3000 in the other? I can set the BS 5 to option 6 or make it not Audio Master, but then I can't use Spotify and AUX on it.
Sorry your right A. Option 6 is the right answer. I didn't proof read it.
If your BS has latest sw, it should support A.OoPT 5/6.
your BS5 should be A.OPt 0 and BV10 Must be V.OPT 2.
I'm assuming that you have connected Beolabs to your BS3000.
Stefan
